Einleitung
If your screen is damaged or has dust underneath the plastic cover, it may need to be removed. This guide provides steps to install the LCD screens and call speaker for your Motorola Razr V3.
Was du brauchst
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
Remove the battery by pushing down on the top and pulling it away from the phone.
Use tweezers to pry off the four rubber screw covers from the inside face.
Use the spudger to pry off the plastic lens that covers the LCD screen.
Use the tweezers to gently pry the silver ribbon cable up towards you.
Use he tweezers to flip up the tab.
With the tab up, gently pull the copper ribbon cable out.
Use the tweezers to gently fold the buttons away from the phone.
Use the spudger the speaker from the phone.
6 weitere Personen haben diese Anleitung absolviert.
