Zum Hauptinhalt wechseln
Motorola Razr V3 Motherboard Replacement
Was du brauchst
  1. Motorola Razr V3 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola Razr V3 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Motherboard Replacement: Schritt 2, Bild 1 von 2 Motorola Razr V3 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Motherboard Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Remove the SIM card by pulling it toward the top of the phone with your thumb.
  4. Motorola Razr V3 Motherboard Replacement, Antenna: Schritt 4, Bild 1 von 1
    • Unscrew the two 5mm T6 Torx screws form the phone.
  5. Motorola Razr V3 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
    • You can rotate the phone left and right to get easier access while prying.
    • Make sure to fold back of phone down (or left depending on your orientation) after separating from body as there is ribbon connecting the back to the phone's body which can be ripped if pulled the wrong way.
    • The tab as well as the plastic clips are fragile, be careful when using them.
  6. Motorola Razr V3 Motherboard Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
    • The clear part below the circuit board is the antenna.
  7. Motorola Razr V3 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
    • These clips are also fragile.
    • When reassembling, make sure the copper piece of the antenna is properly inserted between the two copper clips that stick up from the phone.
  8. Motorola Razr V3 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Use a spudger or blue opening tool to pry the motherboard away from the back casing.
    • The speaker and the motherboard are magnetic and will most likely come up with each other.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 3-46, Amido Spring 2013 Mitglied von Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
Step 7 seems wrong to me. I almost broke my phone following the instructions.
To remove the antenna, you remove the two black plastic/rubber stoppers by prying them out. Then you have access to the two tabs underneath the stoppers. There are also tabs on the clear housing than hook into the bottom of the tabs on the main casing used to hold the two parts of the case together. I started on one side and gently went across, prying the tabs up.
Justin - Antwort Teilen
Ok, where can i buy v3i motherbord cheaper that refubrished v3i?
Alexandr Vasilenko - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 44
Letzte 30 Tage: 141
Insgesamt: 6,170
