Einleitung
The purpose of this repair guide is to show how to replace the lower outer casing.
Was du brauchst
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Remove the battery by pushing in the top of the battery and lifting it away from the phone.
Use the plastic opening tool to pop the bottom and the sides off the back casing.
Pull out the two black rubber covers using tweezers.
Pull out the motherboard.
You may also now replace the bottom lower casing
Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
Eine weitere Person hat diese Anleitung absolviert.
