Zum Hauptinhalt wechseln
Motorola Razr V3c Lower Casing (CDMA) Replacement
Was du brauchst
  1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): Schritt 1, Bild 1 von 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): Schritt 1, Bild 2 von 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): Schritt 1, Bild 3 von 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 2, Bild 1 von 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): Schritt 3, Bild 1 von 1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 5, Bild 1 von 1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 6, Bild 1 von 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 7, Bild 1 von 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 7, Bild 2 von 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 8, Bild 1 von 1
    • Pull out the speaker.
  9. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): Schritt 9, Bild 1 von 2 Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): Schritt 9, Bild 2 von 2
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
  10. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): Schritt 10, Bild 1 von 1
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  11. Motorola Razr V3c Lower Casing (CDMA) Replacement: Schritt 11, Bild 1 von 1
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
krisko
104 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 11-4, Forte Winter 2010 Mitglied von Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 6,282
