Einleitung
This guide will show you how to remove the motherboard on a Motorola V3c.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Unscrew the two screws in the back using the T6.
    • Unscrew the two screws in the back using the T6.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  6. Peel off the connector between the motherboard and the body of the phone.
    • Peel off the connector between the motherboard and the body of the phone.
  7. Pull out the two black rubber covers using tweezers. The second rubber cover is much harder to get out.
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  8. Pull out the white plastic cover by unclipping the two plastic pieces shown. Pull out the white plastic cover by unclipping the two plastic pieces shown.
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  9. Pull out the speaker.
    • Pull out the speaker.
  10. Pull out the motherboard. You may also now replace the bottom lower casing
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Joshua Ruehlig
503 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 11-4, Forte Winter 2010 Mitglied von Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Mitglieder
8 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 6,408
