Was du brauchst
Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
Gently pull the SIM Card toward the top of the phone with your finger.
Carefully use a plastic opening tool to pry back panel open.
Carefully open out the back panel to the side of the phone corresponding with the hinge.
Use tweezers to disconnect the copper ribbon from the inside of the back panel.
Use tweezers to remove the tiny red and blue rubber covers located on the top of the antenna.
Use a plastic opening tool to pry the edge of the antenna away from back panel.
Lift antenna away from back panel.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
