Zum Hauptinhalt wechseln
Motorola Razr V3m Speaker Replacement
Was du brauchst
  1. Motorola Razr V3m Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola Razr V3m Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Speaker Replacement: Schritt 2, Bild 1 von 2 Motorola Razr V3m Speaker Replacement: Schritt 2, Bild 2 von 2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Speaker Replacement, SIM Card: Schritt 3, Bild 1 von 2 Motorola Razr V3m Speaker Replacement, SIM Card: Schritt 3, Bild 2 von 2
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Speaker Replacement, Antenna: Schritt 4, Bild 1 von 2 Motorola Razr V3m Speaker Replacement, Antenna: Schritt 4, Bild 2 von 2
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Speaker Replacement: Schritt 5, Bild 1 von 1
    • Carefully use a plastic opening tool to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Speaker Replacement: Schritt 6, Bild 1 von 2 Motorola Razr V3m Speaker Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Speaker Replacement: Schritt 7, Bild 1 von 1
    • Use tweezers to remove the tiny red and blue rubber covers located on the top of the antenna.
  8. Motorola Razr V3m Speaker Replacement: Schritt 8, Bild 1 von 2 Motorola Razr V3m Speaker Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening tool to pry the edge of the antenna away from back panel.
    • The antenna may be fastened with two grey clips on either side. If this is so, unfasten two plastic clips located on the edge of the antenna.
    • Lift antenna away from back panel.
  9. Motorola Razr V3m Speaker Replacement, Speaker: Schritt 9, Bild 1 von 1
    • The Speaker is the round piece located beneath the antenna.
    • Use tweezers to remove the speaker.
Abschluss
UMass Dartmouth, Team 3-2, Shastany Fall 2015 Mitglied von UMass Dartmouth, Team 3-2, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 282
