Zum Hauptinhalt wechseln
Motorola Rival Keyboard Replacement
Was du brauchst
  1. Motorola Rival Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Motorola Rival Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Motorola Rival Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Locate the lever to release the cover of the device.
    • Push down on lever and pull the cover away from the device.
  2. Motorola Rival Keyboard Replacement: Schritt 2, Bild 1 von 2 Motorola Rival Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Locate the battery on the back of the phone.
    • Remove the battery from the phone.
  3. Motorola Rival Keyboard Replacement: Schritt 3, Bild 1 von 2 Motorola Rival Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Take out the 6 screws on the corners of the phone in order to get inside of the phone.
  4. Motorola Rival Keyboard Replacement: Schritt 4, Bild 1 von 2 Motorola Rival Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Using the pry tool gently remove the back piece of the phone from the front piece.
  5. Motorola Rival Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Using the pry tool remove the camera button from the phone.
  6. Motorola Rival Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Using the pry tool, remove the lock/mute button.
  7. Motorola Rival Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Using the pry, remove the volume buttons.
  8. Motorola Rival Keyboard Replacement: Schritt 8, Bild 1 von 2 Motorola Rival Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Using a screw driver, locate and remove the screws that connect the keyboard to the mother board.
  9. Motorola Rival Keyboard Replacement: Schritt 9, Bild 1 von 3 Motorola Rival Keyboard Replacement: Schritt 9, Bild 2 von 3 Motorola Rival Keyboard Replacement: Schritt 9, Bild 3 von 3
    • With the pry tool, gently lift the mother board out of the frame.
    • Be sure to be gentle when lifting it up.
  10. Motorola Rival Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the keyboard from the frame.
    • Replace with new keyboard
Abschluss
Sekani Paul
231 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-8, Bhusal Fall 2015 Mitglied von UMass Dartmouth, Team 1-8, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G8
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 225
