Zum Hauptinhalt wechseln
Motorola SURFboard SB5101 Outer Cover Replacement
Was du brauchst
  1. Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: Schritt 1, Bild 1 von 3 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: Schritt 1, Bild 2 von 3 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: Schritt 1, Bild 3 von 3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: Schritt 2, Bild 1 von 3 Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: Schritt 2, Bild 2 von 3 Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: Schritt 2, Bild 3 von 3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: Schritt 3, Bild 1 von 3 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: Schritt 3, Bild 2 von 3 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: Schritt 3, Bild 3 von 3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
Abschluss
In order to learn how to re-assembly your device, visit the Reassembly Guide.
Eine weitere Person hat diese Anleitung absolviert.
Bhavik Patel
276 Reputation
2 Anleitungen geschrieben
Clemson, Team 1-2, Benson Fall 2014 Mitglied von Clemson, Team 1-2, Benson Fall 2014
CLEM-BENSON-F14S1G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 1,148
