Einleitung
The radio button contacts are responsible for transmitting the radio user's touch to the circuit board. Malfunctioning button contacts can make the radio unresponsive when a button is pressed. Follow the steps below to properly clean the button contacts to restore button function.
Was du brauchst
Remove the back battery cover by pressing the tab to the left, and lifting.
Remove the batteries currently in the radio.
The orientation of the batteries is specified in the battery compartment.
Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
The button contacts can be seen in the red box of the picture.
Dip q-tip in rubbing isopropyl alcohol, and swab button contacts to clean.
Note: Rubbing alcohol will evaporate, and does not need to be wiped off of contacts.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
