Einleitung
You will learn how to access your motherboard using the screwdriver and replace your speakers using the spudger.
Was du brauchst
Slide the back cover down.
Lift the back cover up.
Pry the battery out with the spudger
After removing the Battery remove the two screws with a T4 screwdriver.
With the spudger, go around the seam of the phone and pry away the back chassis.
Fast fertig!
Abschluss
