Zum Hauptinhalt wechseln
Motorola V180 Motherboard Replacement
Was du brauchst
  1. Motorola V180 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V180 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V180 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: Schritt 2, Bild 1 von 3 Motorola V180 Motherboard Replacement, Motherboard: Schritt 2, Bild 2 von 3 Motorola V180 Motherboard Replacement, Motherboard: Schritt 2, Bild 3 von 3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: Schritt 3, Bild 1 von 2 Motorola V180 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
Abschluss
Tyler Knisley
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 6-16, Maness Spring 2010 Mitglied von Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 1,565
