Zum Hauptinhalt wechseln
Motorola V180 LCD screen and connector ribbon replacement
Was du brauchst
  1. Motorola V180 LCD screen and connector ribbon replacement, Connector Ribbon: Schritt 1, Bild 1 von 1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 LCD screen and connector ribbon replacement: Schritt 2, Bild 1 von 1
    • Remove the four screws securing the front cover.
  3. Motorola V180 LCD screen and connector ribbon replacement: Schritt 3, Bild 1 von 1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 LCD screen and connector ribbon replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 LCD screen and connector ribbon replacement: Schritt 5, Bild 1 von 1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 LCD screen and connector ribbon replacement: Schritt 6, Bild 1 von 1
    • Use a soldering iron to detach the connector ribbon from the phone.
  7. Motorola V180 LCD screen and connector ribbon replacement, Motherboard: Schritt 7, Bild 1 von 3 Motorola V180 LCD screen and connector ribbon replacement, Motherboard: Schritt 7, Bild 2 von 3 Motorola V180 LCD screen and connector ribbon replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Power off the Motorola V180.
    • Flip the phone over to its back side.
    • Hold down the button and slide off the back cover.
    • Remove the battery.
  8. Motorola V180 LCD screen and connector ribbon replacement: Schritt 8, Bild 1 von 3 Motorola V180 LCD screen and connector ribbon replacement: Schritt 8, Bild 2 von 3 Motorola V180 LCD screen and connector ribbon replacement: Schritt 8, Bild 3 von 3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  9. Motorola V180 LCD screen and connector ribbon replacement: Schritt 9, Bild 1 von 2 Motorola V180 LCD screen and connector ribbon replacement: Schritt 9, Bild 2 von 2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard.
  10. Motorola V180 LCD screen and connector ribbon replacement, Screen and Connector Ribbon: Schritt 10, Bild 1 von 2 Motorola V180 LCD screen and connector ribbon replacement, Screen and Connector Ribbon: Schritt 10, Bild 2 von 2
    • Now that the connector ribbon is loose, the screen (white part) can swing away.
    • Some of the black "tape" can be peeled back, but the screen is still attached. Further work may be necessary to fully separate this part.
  11. Motorola V180 LCD screen and connector ribbon replacement: Schritt 11, Bild 1 von 2 Motorola V180 LCD screen and connector ribbon replacement: Schritt 11, Bild 2 von 2
    • Slide out the part of the connector ribbon that was just attached to the motherboard through this narrow slot in the phone.
    • This may require some effort as it is a tight fit, so proceed with caution to avoid tearing the ribbon while maneuvering it through the slot.
    • Once the connector ribbon is successfully removed from the slot, proceed to remove the entire unit from the phone.
Abschluss
Tyler Knisley
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 6-16, Maness Spring 2010 Mitglied von Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 3,354
