Zum Hauptinhalt wechseln
Motorola V2397 Front Cover Replacement
Was du brauchst
  1. Motorola V2397 Front Cover Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V2397 Front Cover Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V2397 Front Cover Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Front Cover Replacement: Schritt 2, Bild 1 von 2 Motorola V2397 Front Cover Replacement: Schritt 2, Bild 2 von 2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Front Cover Replacement, Back Cover: Schritt 3, Bild 1 von 2 Motorola V2397 Front Cover Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Front Cover Replacement: Schritt 4, Bild 1 von 2 Motorola V2397 Front Cover Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Front Cover Replacement, Side Buttons: Schritt 5, Bild 1 von 2 Motorola V2397 Front Cover Replacement, Side Buttons: Schritt 5, Bild 2 von 2
    • Lift and remove buttons by hand
  6. Motorola V2397 Front Cover Replacement, Phone: Schritt 6, Bild 1 von 2 Motorola V2397 Front Cover Replacement, Phone: Schritt 6, Bild 2 von 2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  7. Motorola V2397 Front Cover Replacement, Keypad: Schritt 7, Bild 1 von 3 Motorola V2397 Front Cover Replacement, Keypad: Schritt 7, Bild 2 von 3 Motorola V2397 Front Cover Replacement, Keypad: Schritt 7, Bild 3 von 3
    • Grip the top of the rubber keypad with your thumb and index finger
    • While holding the keypad start to peel it back from the front cover until the keypad is completely detached
  8. Motorola V2397 Front Cover Replacement, Speaker: Schritt 8, Bild 1 von 2 Motorola V2397 Front Cover Replacement, Speaker: Schritt 8, Bild 2 von 2
    • Use the iFixit opening tool to lift the speaker off the front cover.
  9. Motorola V2397 Front Cover Replacement, Front Cover: Schritt 9, Bild 1 von 2 Motorola V2397 Front Cover Replacement, Front Cover: Schritt 9, Bild 2 von 2
    • Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
Abschluss
Connor
201 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-6, Sullivan Winter 2015 Mitglied von USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 116
