Zum Hauptinhalt wechseln
Motorola V2397 Motherboard/Screen Replacement
Was du brauchst
  1. Motorola V2397 Motherboard/Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V2397 Motherboard/Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V2397 Motherboard/Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Motherboard/Screen Replacement: Schritt 2, Bild 1 von 2 Motorola V2397 Motherboard/Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Motherboard/Screen Replacement, Back Cover: Schritt 3, Bild 1 von 2 Motorola V2397 Motherboard/Screen Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Motherboard/Screen Replacement: Schritt 4, Bild 1 von 2 Motorola V2397 Motherboard/Screen Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Motherboard/Screen Replacement, Phone: Schritt 5, Bild 1 von 2 Motorola V2397 Motherboard/Screen Replacement, Phone: Schritt 5, Bild 2 von 2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  6. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: Schritt 6, Bild 1 von 2 Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: Schritt 6, Bild 2 von 2
    • Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
    • Carefully separate the screen from the motherboard
    • Note the cable connecting the screen to the motherboard. Do not pull the screen too far from the motherboard or you may damage the cable
  7. Motorola V2397 Motherboard/Screen Replacement: Schritt 7, Bild 1 von 2 Motorola V2397 Motherboard/Screen Replacement: Schritt 7, Bild 2 von 2
    • Lift the flap of the connector on the motherboard using a spudger
    • Carefully remove the FFC cable from the connector
    • The screen should now be free from the motherboard
Abschluss
Chris
501 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-6, Sullivan Winter 2015 Mitglied von USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 138
