Einleitung
Replacing the phone's headphone jack.
Was du brauchst
Locate the silver button on the back of the phone, near the bottom.
Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
Now that the battery is exposed, use your fingers to remove the it from the phone.
Note the metal connections on the phone, which are now exposed with the battery removed.
There are corresponding metal connectors on the replacement battery.
When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
Use Spudger to remove rubber plug from upper left corner of the back of the phone
Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
