Zum Hauptinhalt wechseln
Einleitung
This guide is used for taking apart and/or replacing the computer portion of the phone.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery
    • Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery
  2. Apply pressure to the bottom corners of the battery, and then push upwards to lever the battery out.
    • Apply pressure to the bottom corners of the battery, and then push upwards to lever the battery out.
  3. Remove the rubber screw covers using a plastic spudger. Use a T-6 screw bit to remove the screws. Use a T-6 screw bit to remove the screws.
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T-6 screw bit to remove the screws.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Unscrew the antenna.
    • Unscrew the antenna.
  6. Use a plastic opening tool to undo the latches at the indicated spots. Dental tools may be used in place of a plastic opening tool, as they are difficult to use. Warning: exercise caution as the plastic can break.
    • Use a plastic opening tool to undo the latches at the indicated spots.
    • Dental tools may be used in place of a plastic opening tool, as they are difficult to use.
    • Warning: exercise caution as the plastic can break.
  7. Remove the computer connection (copper flap) by first loosening it with a plastic opening tool. Lift the connection up with your finger.
    • Remove the computer connection (copper flap) by first loosening it with a plastic opening tool.
    • Lift the connection up with your finger.
  8. Use your finger to remove the pressure pad from the buttons on the side of the casing. Remove the plastic flap from around the buttons by lifting it up and pulling it out. Gently lift the logic board up.
    • Use your finger to remove the pressure pad from the buttons on the side of the casing.
    • Remove the plastic flap from around the buttons by lifting it up and pulling it out.
    • Gently lift the logic board up.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
gregatron
72 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 6-6, Maness Fall 2009 Mitglied von Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,962
