Einleitung
This guide is for removing the phone's earpiece speaker.
Was du brauchst
Unscrew the four cover screws using a T6 Torx screwdriver, turning counterclockwise.
Carefully remove the protective cover from the circuitry.
Slowly peel the black rubber gasket off of the circuit board.
Carefully move the camera out of the way using your hand.
Use a flat tool to disconnect the upper and lower circuit boards.
Fast fertig!
Abschluss
