Zum Hauptinhalt wechseln
Motorola V551 Keypad Key Replacement
Was du brauchst
  1. Motorola V551 Keypad Key Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola V551 Keypad Key Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Keypad Key Replacement: Schritt 2, Bild 1 von 1
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Keypad Key Replacement, Circuit Board: Schritt 3, Bild 1 von 3 Motorola V551 Keypad Key Replacement, Circuit Board: Schritt 3, Bild 2 von 3 Motorola V551 Keypad Key Replacement, Circuit Board: Schritt 3, Bild 3 von 3
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Keypad Key Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the antenna.
  5. Motorola V551 Keypad Key Replacement: Schritt 5, Bild 1 von 3 Motorola V551 Keypad Key Replacement: Schritt 5, Bild 2 von 3 Motorola V551 Keypad Key Replacement: Schritt 5, Bild 3 von 3
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Keypad Key Replacement: Schritt 6, Bild 1 von 2 Motorola V551 Keypad Key Replacement: Schritt 6, Bild 2 von 2
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Keypad Key Replacement: Schritt 7, Bild 1 von 3 Motorola V551 Keypad Key Replacement: Schritt 7, Bild 2 von 3 Motorola V551 Keypad Key Replacement: Schritt 7, Bild 3 von 3
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
  8. Motorola V551 Keypad Key Replacement, Keypad: Schritt 8, Bild 1 von 3 Motorola V551 Keypad Key Replacement, Keypad: Schritt 8, Bild 2 von 3 Motorola V551 Keypad Key Replacement, Keypad: Schritt 8, Bild 3 von 3
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
  9. Motorola V551 Keypad Key Replacement, Keypad Key: Schritt 9, Bild 1 von 2 Motorola V551 Keypad Key Replacement, Keypad Key: Schritt 9, Bild 2 von 2
    • Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
    • Be careful while applying the super glue as it can be quite strong.
  10. Motorola V551 Keypad Key Replacement: Schritt 10, Bild 1 von 2 Motorola V551 Keypad Key Replacement: Schritt 10, Bild 2 von 2
    • Carefully place key onto the key pad so that it will be properly oriented and in line with the other keys.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
gregatron
105 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 6-6, Maness Fall 2009 Mitglied von Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 1,971
