Einleitung
This guide is for removing the screen of a Motorola V551. A flat tool may be helpful for step 5, but it is not necessary.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Unscrew the four cover screws by using a T6 Torx screwdriver, turning counterclockwise.
Carefully remove the protective cover from the circuitry.
Slowly peel the black rubber gasket off of the circuit board.
Carefully move the camera out of the way by using your hand.
Use a flat tool to separate the connection between the upper and lower circuit boards.
2 weitere Nutzer haben diese Anleitung absolviert.
