Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide is useful when encountering broken or stuck keys.
  1. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery.
    • Push down on the silver button while sliding the back plate down to reveal the battery.
  2. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
    • Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
  3. Move the the metal slider towards the top of the phone until it clicks out of its original position. Slide out and remove the SIM card. Slide out and remove the SIM card.
    • Move the the metal slider towards the top of the phone until it clicks out of its original position.
    • Slide out and remove the SIM card.
  4. Grip the antenna and twist it counterclockwise to loosen it. When it has been loosened all the way, pull gently to remove the antenna piece.
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Remove the screw covers over the two top screws by prying gently with a pin. The large cover in the upper left of the back plate has no screw behind it, so should not be removed. The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
    • Remove the screw covers over the two top screws by prying gently with a pin.
    • The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
  6. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws.
    • Remove all four 6.0 mm Torx screws.
  7. Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs. Separate and detach the rear casing. Separate and detach the rear casing.
    • Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs.
    • Separate and detach the rear casing.
  8. Separate the front ribbon cable from the board with a plastic opening tool. Separate the front ribbon cable from the board with a plastic opening tool. Separate the front ribbon cable from the board with a plastic opening tool.
    • Separate the front ribbon cable from the board with a plastic opening tool.
  9. Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard. Lift out the motherboard only after all cables have been disconnected.  Try to touch it only from the sides. Lift out the motherboard only after all cables have been disconnected.  Try to touch it only from the sides.
    • Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard.
    • Lift out the motherboard only after all cables have been disconnected. Try to touch it only from the sides.
  10. With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom. With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom. With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom.
    • With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Chad Brantley
32 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-50, Amido Fall 2010 Mitglied von Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Mitglieder
24 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 960
