Zum Hauptinhalt wechseln
Motorola V557 Motherboard Replacement
Was du brauchst
  1. Motorola V557 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V557 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V557 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Motherboard Replacement: Schritt 2, Bild 1 von 2 Motorola V557 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Motherboard Replacement, SIM Card: Schritt 3, Bild 1 von 3 Motorola V557 Motherboard Replacement, SIM Card: Schritt 3, Bild 2 von 3 Motorola V557 Motherboard Replacement, SIM Card: Schritt 3, Bild 3 von 3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Motherboard Replacement, Antenna: Schritt 4, Bild 1 von 2 Motorola V557 Motherboard Replacement, Antenna: Schritt 4, Bild 2 von 2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Motherboard Replacement, Rear Casing: Schritt 5, Bild 1 von 3 Motorola V557 Motherboard Replacement, Rear Casing: Schritt 5, Bild 2 von 3 Motorola V557 Motherboard Replacement, Rear Casing: Schritt 5, Bild 3 von 3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Motherboard Replacement: Schritt 6, Bild 1 von 3 Motorola V557 Motherboard Replacement: Schritt 6, Bild 2 von 3 Motorola V557 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Motherboard Replacement: Schritt 7, Bild 1 von 3 Motorola V557 Motherboard Replacement: Schritt 7, Bild 2 von 3 Motorola V557 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
  8. Motorola V557 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 3 Motorola V557 Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 3 Motorola V557 Motherboard Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Separate the front ribbon cable from the board with a plastic opening tool.
  9. Motorola V557 Motherboard Replacement: Schritt 9, Bild 1 von 3 Motorola V557 Motherboard Replacement: Schritt 9, Bild 2 von 3 Motorola V557 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard.
    • Lift out the motherboard only after all cables have been disconnected. Try to touch it only from the sides.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Chad Brantley
32 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-50, Amido Fall 2010 Mitglied von Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 13
Insgesamt: 1,861
