Zum Hauptinhalt wechseln
Motorola V557 Screen Replacement
Was du brauchst
  1. Motorola V557 Screen Replacement, Faceplate: Schritt 1, Bild 1 von 3 Motorola V557 Screen Replacement, Faceplate: Schritt 1, Bild 2 von 3 Motorola V557 Screen Replacement, Faceplate: Schritt 1, Bild 3 von 3
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  2. Motorola V557 Screen Replacement: Schritt 2, Bild 1 von 2 Motorola V557 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 3.8 mm T-6 Torx screws.
  3. Motorola V557 Screen Replacement: Schritt 3, Bild 1 von 2 Motorola V557 Screen Replacement: Schritt 3, Bild 2 von 2
    • Separate the cover from the edges using a plastic opening tool.
  4. Motorola V557 Screen Replacement: Schritt 4, Bild 1 von 2 Motorola V557 Screen Replacement: Schritt 4, Bild 2 von 2
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  5. Motorola V557 Screen Replacement, Camera: Schritt 5, Bild 1 von 1
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  6. Motorola V557 Screen Replacement: Schritt 6, Bild 1 von 2 Motorola V557 Screen Replacement: Schritt 6, Bild 2 von 2
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  7. Motorola V557 Screen Replacement: Schritt 7, Bild 1 von 2 Motorola V557 Screen Replacement: Schritt 7, Bild 2 von 2
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  8. Motorola V557 Screen Replacement: Schritt 8, Bild 1 von 2 Motorola V557 Screen Replacement: Schritt 8, Bild 2 von 2
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  9. Motorola V557 Screen Replacement: Schritt 9, Bild 1 von 3 Motorola V557 Screen Replacement: Schritt 9, Bild 2 von 3 Motorola V557 Screen Replacement: Schritt 9, Bild 3 von 3
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  10. Motorola V557 Screen Replacement: Schritt 10, Bild 1 von 2 Motorola V557 Screen Replacement: Schritt 10, Bild 2 von 2
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
  11. Motorola V557 Screen Replacement, Screen: Schritt 11, Bild 1 von 3 Motorola V557 Screen Replacement, Screen: Schritt 11, Bild 2 von 3 Motorola V557 Screen Replacement, Screen: Schritt 11, Bild 3 von 3
    • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
    • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
Abschluss
Cal Poly, Team 7-50, Amido Fall 2010 Mitglied von Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,735
