Zum Hauptinhalt wechseln
Motorola V60c Keypad and Keypad Logic Board Replacement
Was du brauchst
  1. Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: Schritt 1, Bild 2 von 2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 2, Bild 1 von 2 Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Keypad and Keypad Logic Board Replacement, Keypad and Keypad Logic Board: Schritt 3, Bild 1 von 1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 4, Bild 1 von 2 Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 4, Bild 2 von 2
    • Use plastic opening tool to pry up back cover from two side clips.
    • NOTE: Sticker might be attached to rest of phone.
  5. Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 5, Bild 1 von 1
    • Remove the back cover.
  6. Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 6, Bild 1 von 2 Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 7, Bild 1 von 2 Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 7, Bild 2 von 2
    • Remove the keypad logic board.
    • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  8. Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 8, Bild 1 von 3 Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 8, Bild 2 von 3 Motorola V60c Keypad and Keypad Logic Board Replacement: Schritt 8, Bild 3 von 3
    • Remove the keypad.
Abschluss
Ryan Kuroiwa
1 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 25-86, Amido Spring 2010 Mitglied von Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 2,210
