Einleitung
Step-by-step guide to replacing the keypad sensor.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Flip phone to see back cover.
    • Flip phone to see back cover.
    • Using either finger or spugder tool press button located near the top of phone by the antenna.
  2. Pry up back plate from phone to reveal battery.
    • Pry up back plate from phone to reveal battery.
    • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
    • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
    • Simultaneously press indicated buttons on both sides of phone.
    • Separate back plate from the rest of phone.
    • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
    • Gently lift logic board from back plate.
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
    • Once logic board is removed lift the green keypad sensor for the front plate.
Abschluss
Elizabeth OBrien
Mitglied seit 26.04.2010
31 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 30-40, Garner Spring 2010 Mitglied von Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Mitglieder
14 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,835
