Zum Hauptinhalt wechseln
Einleitung
This is a guide showing how to replace the Motorola V60 speakers.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove battery cover by pushing down release lever at top of phone while prying off cover. Set cover aside. Set cover aside.
    • Remove battery cover by pushing down release lever at top of phone while prying off cover.
    • Set cover aside.
  2. Remove battery by grabbing it near the bottom and lifting out. Remove battery by grabbing it near the bottom and lifting out.
    • Remove battery by grabbing it near the bottom and lifting out.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Unscrew four corner screws with T6 screwdriver. Note: Top screws are silver and short while bottom screws are black and longer.
    • Unscrew four corner screws with T6 screwdriver.
    • Note: Top screws are silver and short while bottom screws are black and longer.
  5. Pry off back chassis by wedging spudger in crevice between back panel and phone and lifting. Pry off back chassis by wedging spudger in crevice between back panel and phone and lifting.
    • Pry off back chassis by wedging spudger in crevice between back panel and phone and lifting.
  6. Insert spudger between speaker and back chassis and lifting.
    • Insert spudger between speaker and back chassis and lifting.
    • Note: This may take some effort.
Abschluss
Eric Freeman
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 8-48, Regan Winter 2010 Mitglied von Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Mitglieder
13 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,457
