Einleitung
This is a guide showing how to replace the Motorola V60 speakers.
Was du brauchst
Push in release lever towards top of phone, then use blue spudger to pry case off.
After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
Set cover aside in a safe location.
Carefully grab battery towards bottom of phone.
Lift from bottom and take out of phone, set aside in a safe location.
Insert an iFixit opening tool into phone in between back panel and body of phone.
Carefully pry up until back panel comes off, then remove with hands and set aside.
Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
