Einleitung
This guide will help show you how to replace the keypad.
Was du brauchst
Press down on the back button while pulling away from the body of the phone to release the back cover.
Remove the battery from the phone by gently pulling upward on the battery with your fingers.
Unscrew the antenna with a clockwise motion and pull to remove the antenna.
Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver.
Fast fertig!
Ziellinie
