Zum Hauptinhalt wechseln
Motorola V710 Logic Board Replacement
Was du brauchst
  1. Motorola V710 Logic Board Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola V710 Logic Board Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola V710 Logic Board Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Logic Board Replacement: Schritt 2, Bild 1 von 3 Motorola V710 Logic Board Replacement: Schritt 2, Bild 2 von 3 Motorola V710 Logic Board Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Logic Board Replacement, Logic Board: Schritt 3, Bild 1 von 2 Motorola V710 Logic Board Replacement, Logic Board: Schritt 3, Bild 2 von 2
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Logic Board Replacement: Schritt 4, Bild 1 von 2 Motorola V710 Logic Board Replacement: Schritt 4, Bild 2 von 2
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Logic Board Replacement: Schritt 5, Bild 1 von 3 Motorola V710 Logic Board Replacement: Schritt 5, Bild 2 von 3 Motorola V710 Logic Board Replacement: Schritt 5, Bild 3 von 3
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Logic Board Replacement: Schritt 6, Bild 1 von 2 Motorola V710 Logic Board Replacement: Schritt 6, Bild 2 von 2
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Logic Board Replacement: Schritt 7, Bild 1 von 2 Motorola V710 Logic Board Replacement: Schritt 7, Bild 2 von 2
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Logic Board Replacement: Schritt 8, Bild 1 von 3 Motorola V710 Logic Board Replacement: Schritt 8, Bild 2 von 3 Motorola V710 Logic Board Replacement: Schritt 8, Bild 3 von 3
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Logic Board Replacement: Schritt 9, Bild 1 von 1
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Logic Board Replacement: Schritt 10, Bild 1 von 2 Motorola V710 Logic Board Replacement: Schritt 10, Bild 2 von 2
    • Remove the logic board.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 8-49, Regan Winter 2010 Mitglied von Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Mitglieder
16 Anleitungen geschrieben
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 15
Insgesamt: 2,059
