Zum Hauptinhalt wechseln
Motorola W315 Speaker Replacement
Was du brauchst
  1. Motorola W315 Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Insert the new battery.
  3. Motorola W315 Speaker Replacement, Rear Case: Schritt 4, Bild 1 von 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Speaker Replacement: Schritt 5, Bild 1 von 3 Motorola W315 Speaker Replacement: Schritt 5, Bild 2 von 3 Motorola W315 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Speaker Replacement, Speaker: Schritt 6, Bild 1 von 3 Motorola W315 Speaker Replacement, Speaker: Schritt 6, Bild 2 von 3 Motorola W315 Speaker Replacement, Speaker: Schritt 6, Bild 3 von 3
    • Using back of the plastic opening tool, push the speaker out of the casing.
    • Remove existing speaker.
    • Replace with new speaker
Abschluss
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
399 Reputation
4 Anleitungen geschrieben
Clemson, Team 6-3, Benson Spring 2014 Mitglied von Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 139
