Zum Hauptinhalt wechseln
Motorola W385 Top Logic Board Replacement
Was du brauchst
  1. Motorola W385 Top Logic Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Top Logic Board Replacement: Schritt 2, Bild 1 von 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Top Logic Board Replacement, Front Casing: Schritt 3, Bild 1 von 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Top Logic Board Replacement: Schritt 4, Bild 1 von 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Top Logic Board Replacement: Schritt 5, Bild 1 von 2 Motorola W385 Top Logic Board Replacement: Schritt 5, Bild 2 von 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Top Logic Board Replacement: Schritt 6, Bild 1 von 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 Top Logic Board Replacement, Top Logic Board: Schritt 7, Bild 1 von 1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 Top Logic Board Replacement: Schritt 8, Bild 1 von 3 Motorola W385 Top Logic Board Replacement: Schritt 8, Bild 2 von 3 Motorola W385 Top Logic Board Replacement: Schritt 8, Bild 3 von 3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 Top Logic Board Replacement: Schritt 9, Bild 1 von 3 Motorola W385 Top Logic Board Replacement: Schritt 9, Bild 2 von 3 Motorola W385 Top Logic Board Replacement: Schritt 9, Bild 3 von 3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
Abschluss
Javier Mendez
13 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-50, Regan Winter 2010 Mitglied von Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 2,560
