Einleitung
If you are having trouble hearing, this guide will help you replace your speaker.
Was du brauchst
Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
Close the phone before proceeding.
Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
Continue to move around the phone counter clockwise until the casing is separated from the body.
If the casing has not popped off of the body, remove it carefully from the the phone.
After completing Steps 3-6 in the casing repair guide, your phone should look like this.
Use the spudger to unhinge the four clips around the metal casing of the top logic board.
Gently take off the metal casing of the logic board.
Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Place the spudger between the speaker and the clip shown.
Separate the clip from the speaker while lifting on the speaker.
The speaker should separate. Use the tweezers to grab the speaker.
Eine weitere Person hat diese Anleitung absolviert.
