Zum Hauptinhalt wechseln
Motorola W490 Keypad Replacement
Was du brauchst
  1. Motorola W490 Keypad Replacement, Phone Casing: Schritt 1, Bild 1 von 2 Motorola W490 Keypad Replacement, Phone Casing: Schritt 1, Bild 2 von 2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 Keypad Replacement, Battery: Schritt 2, Bild 1 von 2 Motorola W490 Keypad Replacement, Battery: Schritt 2, Bild 2 von 2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 Keypad Replacement, SIM Card: Schritt 3, Bild 1 von 3 Motorola W490 Keypad Replacement, SIM Card: Schritt 3, Bild 2 von 3 Motorola W490 Keypad Replacement, SIM Card: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to make a gap between the SIM card and the phone.
    • Use your thumb and index finger to pull the SIM card from the phone.
  4. Motorola W490 Keypad Replacement, Keypad Membrane: Schritt 4, Bild 1 von 1
    • Open phone so the keypad is facing up.
  5. Motorola W490 Keypad Replacement: Schritt 5, Bild 1 von 1
    • Insert a push pin into the notch located on the left side of the keypad and push the pin under the keypad membrane.
  6. Motorola W490 Keypad Replacement: Schritt 6, Bild 1 von 1
    • Continue working the pin under the keypad membrane until it is elevated enough to grasp.
  7. Motorola W490 Keypad Replacement: Schritt 7, Bild 1 von 1
    • Grasp the keypad membrane firmly and remove it from the phone.
  8. Motorola W490 Keypad Replacement, Lower Metal Frame: Schritt 8, Bild 1 von 2 Motorola W490 Keypad Replacement, Lower Metal Frame: Schritt 8, Bild 2 von 2
    • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
    • Remove all the screws using the Torx T6 Screwdriver.
  9. Motorola W490 Keypad Replacement: Schritt 9, Bild 1 von 3 Motorola W490 Keypad Replacement: Schritt 9, Bild 2 von 3 Motorola W490 Keypad Replacement: Schritt 9, Bild 3 von 3
    • Turn over the phone to the front side and open up the phone, displaying the keypad.
    • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
    • Pull and set the glued plastic cover aside.
    • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
  10. Motorola W490 Keypad Replacement: Schritt 10, Bild 1 von 2 Motorola W490 Keypad Replacement: Schritt 10, Bild 2 von 2
    • Under the plastic cover, locate two star-shaped T5 screws.
    • Use the Torx T5 Screwdriver to remove the two screws.
  11. Motorola W490 Keypad Replacement: Schritt 11, Bild 1 von 3 Motorola W490 Keypad Replacement: Schritt 11, Bild 2 von 3 Motorola W490 Keypad Replacement: Schritt 11, Bild 3 von 3
    • Turn over the phone to the back side of phone where the battery was removed.
    • Use hands to remove the unscrewed rear frame of the phone.
    • Set aside the rear metal frame.
  12. Motorola W490 Keypad Replacement, Circuit Board: Schritt 12, Bild 1 von 3 Motorola W490 Keypad Replacement, Circuit Board: Schritt 12, Bild 2 von 3 Motorola W490 Keypad Replacement, Circuit Board: Schritt 12, Bild 3 von 3
    • Identify the flex cable attachment. Indicated in a red square.
    • Detach the bottom half of the flex cable, pop it off of the circuit board.
    • Pick up the loosened circuit board from the phone and set aside.
  13. Motorola W490 Keypad Replacement, Keypad: Schritt 13, Bild 1 von 3 Motorola W490 Keypad Replacement, Keypad: Schritt 13, Bild 2 von 3 Motorola W490 Keypad Replacement, Keypad: Schritt 13, Bild 3 von 3
    • Lay the circuit board down with the keypad facing up.
    • Grab the corner of the keypad and gently peel it away from the circuit board.
Abschluss
Will Edwards
61 Reputation
9 Anleitungen geschrieben
Clemson, Team 14-1, Benson Fall 2012 Mitglied von Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Mitglieder
23 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 441
