Zum Hauptinhalt wechseln
Motorola W490 LCD Screen Replacement
Was du brauchst
  1. Motorola W490 LCD Screen Replacement, Upper Metal Frame: Schritt 1, Bild 1 von 2 Motorola W490 LCD Screen Replacement, Upper Metal Frame: Schritt 1, Bild 2 von 2
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  2. Motorola W490 LCD Screen Replacement: Schritt 2, Bild 1 von 3 Motorola W490 LCD Screen Replacement: Schritt 2, Bild 2 von 3 Motorola W490 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  3. Motorola W490 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Motorola W490 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Pull the flex cable connection away from the top of the phone.
  4. Motorola W490 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Motorola W490 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Pull the camera connection away from the top of the phone.
  5. Motorola W490 LCD Screen Replacement: Schritt 5, Bild 1 von 3 Motorola W490 LCD Screen Replacement: Schritt 5, Bild 2 von 3 Motorola W490 LCD Screen Replacement: Schritt 5, Bild 3 von 3
    • Pull the upper metal frame away from the phone.
  6. Motorola W490 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 1 von 3 Motorola W490 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 2 von 3 Motorola W490 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 3 von 3
    • Hold the outer phone casing and pull the LCD screen out.
Abschluss
Will Edwards
61 Reputation
9 Anleitungen geschrieben
Clemson, Team 14-1, Benson Fall 2012 Mitglied von Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Mitglieder
23 Anleitungen geschrieben
Ein Kommentar
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 521
