Zum Hauptinhalt wechseln
Motorola XOOM 2 Media Edition Microphone Replacement
Was du brauchst
  1. Motorola XOOM 2 Media Edition Microphone Replacement, Motorola XOOM 2 Media Edition Disassembly: Schritt 1, Bild 1 von 2 Motorola XOOM 2 Media Edition Microphone Replacement, Motorola XOOM 2 Media Edition Disassembly: Schritt 1, Bild 2 von 2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 2, Bild 1 von 2 Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 2, Bild 2 von 2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 3, Bild 1 von 3 Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 3, Bild 2 von 3 Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 3, Bild 3 von 3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Microphone Replacement, Microphone: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Gently pull up rubber housing with tweezers from above microphone.
    • There is adhesive holding down the rubber microphone housing.
  5. Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 5, Bild 1 von 1
    • Using the tweezers, gently pull up the connector off the microphone.
  6. Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 6, Bild 1 von 2 Motorola XOOM 2 Media Edition Microphone Replacement: Schritt 6, Bild 2 von 2
    • Once the connector is removed, use the tweezers to pull up the microphone from its plastic socket.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 168
