Einleitung
Is your microphone not working? Here is a guide to replace the microphone. You will need to purchase a new microphone before beginning.
Was du brauchst
Pry off the back panel using a plastic opening tool.
Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
Once the connector is removed, use the tweezers to pull up the microphone from its plastic socket.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
