Einleitung
Do you have a cracked, shattered, or unresponsive touch screen? This guide will help you replace your screen! You will need to purchase a new screen before beginning.
Was du brauchst
Pry off the back panel using a plastic opening tool.
Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
Use the tweezers to pull up the small chip from its receiver.
Use the tweezers to pull up the larger chip from its receiver.
Use the tweezers to pull up one end of the small piece of tape that is holding the touchscreen controller.
Use the tweezers to pull up and release the thin handle that is attached to the LCD connector.
Use the tweezers to pull out the LCD connector from its receptor.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
