Einleitung
As this replacement guide works on an internal component of the Xoom Wifi, completion of prior steps to remove external parts is necessary.
Was du brauchst
There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
Apply light pressure with hand and slide the back plate till it stops in this position.
There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
As soon as the clips are released the back should slide off.
Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
Once both screws are taken out, lift the rest of the backing out of the way.
Remove the two battery leads with a T-5 Torx screwdriver.
Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
The battery should lift out easily.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
