Zum Hauptinhalt wechseln
Motorola Xoom Wifi Battery Replacement
Was du brauchst
  1. Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: Schritt 1, Bild 1 von 2 Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: Schritt 1, Bild 2 von 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Battery Replacement: Schritt 2, Bild 1 von 2 Motorola Xoom Wifi Battery Replacement: Schritt 2, Bild 2 von 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Battery Replacement: Schritt 3, Bild 1 von 3 Motorola Xoom Wifi Battery Replacement: Schritt 3, Bild 2 von 3 Motorola Xoom Wifi Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Motorola Xoom Wifi Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Battery Replacement: Schritt 5, Bild 1 von 2 Motorola Xoom Wifi Battery Replacement: Schritt 5, Bild 2 von 2
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 3-39, Maness Spring 2014 Mitglied von Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
does anyone know what the function of the black and red wires are? my connector came off the motherboard.
Duli - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 29
Insgesamt: 4,596
