Zum Hauptinhalt wechseln
Motorola Xoom Wifi Speakers Replacement
Was du brauchst
  1. Motorola Xoom Wifi Speakers Replacement, Back Cover Disassembly: Schritt 1, Bild 1 von 2 Motorola Xoom Wifi Speakers Replacement, Back Cover Disassembly: Schritt 1, Bild 2 von 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Speakers Replacement: Schritt 2, Bild 1 von 2 Motorola Xoom Wifi Speakers Replacement: Schritt 2, Bild 2 von 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Speakers Replacement: Schritt 3, Bild 1 von 3 Motorola Xoom Wifi Speakers Replacement: Schritt 3, Bild 2 von 3 Motorola Xoom Wifi Speakers Replacement: Schritt 3, Bild 3 von 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Speakers Replacement, Speakers: Schritt 4, Bild 1 von 2 Motorola Xoom Wifi Speakers Replacement, Speakers: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
Abschluss
Mallika
464 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-39, Maness Spring 2014 Mitglied von Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 247
