Zum Hauptinhalt wechseln
Motorola i1000plus Back Cover Replacement
Was du brauchst
  1. Motorola i1000plus Back Cover Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola i1000plus Back Cover Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola i1000plus Back Cover Replacement, Battery: Schritt 1, Bild 3 von 3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: Schritt 2, Bild 1 von 3 Motorola i1000plus Back Cover Replacement, Antenna: Schritt 2, Bild 2 von 3 Motorola i1000plus Back Cover Replacement, Antenna: Schritt 2, Bild 3 von 3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: Schritt 3, Bild 1 von 3 Motorola i1000plus Back Cover Replacement, Back Cover: Schritt 3, Bild 2 von 3 Motorola i1000plus Back Cover Replacement, Back Cover: Schritt 3, Bild 3 von 3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: Schritt 6, Bild 1 von 3 Motorola i1000plus Back Cover Replacement: Schritt 6, Bild 2 von 3 Motorola i1000plus Back Cover Replacement: Schritt 6, Bild 3 von 3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
Abschluss
Austin Lake
501 Reputation
5 Anleitungen geschrieben
Clemson, Team 13-3, Benson Fall 2013 Mitglied von Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 220
