Zum Hauptinhalt wechseln
Motorola i560 Metal Support Plate Replacement
Was du brauchst
  1. Motorola i560 Metal Support Plate Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Metal Support Plate Replacement: Schritt 2, Bild 1 von 1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Metal Support Plate Replacement, Side Volume Button: Schritt 3, Bild 1 von 1
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Metal Support Plate Replacement: Schritt 4, Bild 1 von 1
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Metal Support Plate Replacement: Schritt 5, Bild 1 von 2 Motorola i560 Metal Support Plate Replacement: Schritt 5, Bild 2 von 2
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Metal Support Plate Replacement: Schritt 6, Bild 1 von 2 Motorola i560 Metal Support Plate Replacement: Schritt 6, Bild 2 von 2
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Metal Support Plate Replacement: Schritt 7, Bild 1 von 3 Motorola i560 Metal Support Plate Replacement: Schritt 7, Bild 2 von 3 Motorola i560 Metal Support Plate Replacement: Schritt 7, Bild 3 von 3
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Metal Support Plate Replacement, Metal Support Plate: Schritt 8, Bild 1 von 3 Motorola i560 Metal Support Plate Replacement, Metal Support Plate: Schritt 8, Bild 2 von 3 Motorola i560 Metal Support Plate Replacement, Metal Support Plate: Schritt 8, Bild 3 von 3
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
Abschluss
Haley S
10 Reputation
4 Anleitungen geschrieben
Clemson, Team 13-6, Benson Spring 2013 Mitglied von Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 149
