Einleitung
Removing the screen requires nearly a complete dis-assembly of the phone.
Was du brauchst
Place thumb on the rubber tab on the lower back of the phone.
Push away from the phone to release back panel.
Gently separate the front and back sides of the phone, as shown in the picture.
Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
By applying force, "pop" the screen out of the connecting hinge frame of the phone.
Carefully slide the speaker ribbon cable through the slot in the front frame of the phone.
After sliding the ribbon cable through the front frame of the phone, the separated screen and phone frame will appear as shown.
