Zum Hauptinhalt wechseln
Motorola i710 Keypad Sensor Replacement
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: Schritt 1, Bild 1 von 2 Motorola i710 Keypad Sensor Replacement, Battery Cover: Schritt 1, Bild 2 von 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Keypad Sensor Replacement, Battery: Schritt 2, Bild 1 von 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: Schritt 3, Bild 1 von 3 Motorola i710 Keypad Sensor Replacement, Motherboard: Schritt 3, Bild 2 von 3 Motorola i710 Keypad Sensor Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: Schritt 4, Bild 1 von 2 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: Schritt 4, Bild 2 von 2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
Abschluss
Katelyn
1 Reputation
2 Anleitungen geschrieben
Clemson, Team 14-2, Benson Fall 2012 Mitglied von Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 450
