Zum Hauptinhalt wechseln
Motorola i710 Motherboard Replacement
Was du brauchst
  1. Motorola i710 Motherboard Replacement, Battery Cover: Schritt 1, Bild 1 von 2 Motorola i710 Motherboard Replacement, Battery Cover: Schritt 1, Bild 2 von 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Motherboard Replacement, Back Casing: Schritt 3, Bild 1 von 3 Motorola i710 Motherboard Replacement, Back Casing: Schritt 3, Bild 2 von 3 Motorola i710 Motherboard Replacement, Back Casing: Schritt 3, Bild 3 von 3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Motorola i710 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 Motorola i710 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 Motorola i710 Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
Abschluss
Carson Meena
16 Reputation
5 Anleitungen geschrieben
Clemson, Team 14-2, Benson Fall 2012 Mitglied von Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 490
