Einleitung
How to replace a damaged antenna.
Was du brauchst
Slide the notch downward while pulling the back cover off to remove it.
Use your fingers to push the battery upward from the bottom.
Lift upwards to remove the battery.
Unscrew the antenna in a counter-clockwise fashion.
Remove the aluminum cover.
Fast fertig!
Abschluss
