Einleitung
Today we are going to repair the speaker system in the phone. This may be due to simple wire disconnections and may require soldering or a replacement of the system.
Was du brauchst
Slide the notch downward while pulling the back cover off to remove it.
Use your fingers to push the battery upward from the bottom.
Lift upwards to remove the battery.
Unscrew the antenna in a counter-clockwise fashion.
Remove the aluminum cover.
Unscrew the 3 screws shown.
Lift up the right part of the Nextel logo and unscrew the screw underneath.
Use the prying tools to wedge out the circular part of the speaker system.
Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
