Einleitung
Before proceeding with the replacement guide, please ensure the headphones are unplugged from any device.
  1. See the speaker replacement guide and follow steps 1 and 2.
    • See the speaker replacement guide and follow steps 1 and 2.
  2. Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
    • Carefully lift the speaker out of its housing while leaving all wires connected.
    • Lift the module out of the headphone cup, leaving all wires attached.
    • Clip the two wires circled in orange.
    • Now that the speaker is free set it aside.
    • Clip the two wires circled in yellow.
    • Replace speaker module and solder it to the two wires circled in orange.
    • Now solder the speaker wires (circled in yellow) back to the module.
    • For soldering see the ifixit soldering guide: Wie man Lötverbindungen herstellt und entlötet
Abschluss
Ben
Mitglied seit 24.02.2014
104 Reputation
1 Anleitung geschrieben
Michigan Tech, Team 5-1, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 Mitglieder
3 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 137
