Zum Hauptinhalt wechseln
Einleitung
This guide details how to remove the camera's case.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a Philips head screwdriver, remove the eight 6mm screws located at the bottom of the device.
    • Using a Philips head screwdriver, remove the eight 6mm screws located at the bottom of the device.
  2. Remove the butterfly nut from the lid arm.
    • Remove the butterfly nut from the lid arm.
  3. Remove the lid-covering.
    • Remove the lid-covering.
  4. Using a Phillips head screwdriver, remove the six 4mm screws from the face of the camera.
    • Using a Phillips head screwdriver, remove the six 4mm screws from the face of the camera.
  5. Gently separate the two halves of the case.
    • Gently separate the two halves of the case.
    • The two halves are connected by a wire. Pulling too roughly can damage the wires and cause the camera to stop functioning.
Abschluss
Sean Hill
434 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team 3-7, Rose Winter 2015 Mitglied von UW Tacoma, Team 3-7, Rose Winter 2015
UWT-ROSE-W15S3G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 129
