Zum Hauptinhalt wechseln
Mountain Bike Brake Lever Replacement
Was du brauchst
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: Schritt 1, Bild 1 von 2 Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: Schritt 1, Bild 2 von 2
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: Schritt 2, Bild 1 von 2 Mountain Bike Brake Lever Replacement: Schritt 2, Bild 2 von 2
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: Schritt 3, Bild 1 von 1
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: Schritt 4, Bild 1 von 2 Mountain Bike Brake Lever Replacement: Schritt 4, Bild 2 von 2
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: Schritt 5, Bild 1 von 1
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: Schritt 6, Bild 1 von 3 Mountain Bike Brake Lever Replacement: Schritt 6, Bild 2 von 3 Mountain Bike Brake Lever Replacement: Schritt 6, Bild 3 von 3
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: Schritt 7, Bild 1 von 3 Mountain Bike Brake Lever Replacement: Schritt 7, Bild 2 von 3 Mountain Bike Brake Lever Replacement: Schritt 7, Bild 3 von 3
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
Abschluss
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 60
Insgesamt: 4,246
